Re: Voltage Regulator repair
Posted by Tom 43 on January 08, 2011 at 14:01:01 from (99.117.18.191):
In Reply to: Re: Voltage Regulator repair posted by John T on January 08, 2011 at 12:11:29:
The statement that "genny feeds loads directly without having to pass through the cutout relay" is NOT correct. All current produced by the generator(with the exception of field current) passes through the cutout relay. The non-battery loads could be directly wired to the armature terminal and work as you say, however, then the lights would only work with the engine running and the ignition circuit would have no power! Look at the picture.
