Posted by John A. on January 08, 2011 at 22:02:55 from (76.1.122.180):
In Reply to: Re: stuck 460D posted by tntleake on January 08, 2011 at 14:33:13:
Tracy, Since you are down this far it would not be too much trouble to go ahead and split the tractor, Because this tractor is 51 yrs old, might as well put in a new Clutch, Pressure Plate, Throw-out Bearing, and chances are it needs a new TA while you are there. The rear ends had problems when the 460/560 were the top of the Hp food chain. Rear ends that were up dated later have a small equilateral triangle ( A Delta mark) stamped after the Serial #. I would not suspect rear end problems at all but the C, P.P., T.o.B. & T.A., I would expect needs to be replaceed. Since to do this one needs to split the tractor it just makes working on the engine easier. something to think about. Later,' John A
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
