Re: IH 300U Hydraulic Pump
Posted by IH fan on January 09, 2011 at 06:49:35 from (208.189.46.250):
In Reply to: IH 300U Hydraulic Pump posted by Nebraska Kirk on January 08, 2011 at 08:49:09:
All you will do if you sand or emery the gear pockets is create more internal leakage. If the pump was working okay before, except for the seal leak, I'd reseal it and try it. However, part of the seal leak may be because the shaft bushings are worn so the shaft is "wiggling" around. If the shaft bushings (I'm assuming bushings and not needle bearings because that's what most gear pumps have) are not worn, just re-seal it.
