IH 300U Hydraulic Pump
Posted by IndyPung on January 08, 2011 at 08:49:09 from (75.207.86.119):
Hey all,
Couple questions on the hydraulic pump on my IH 300U. My tractor has a carbureted engine and my original pump part number is 363779r94. My seals were leaking on my pump and getting hydraulic oil in the distributor housing. So I took off the pump and took it apart and sure enough the seals look pretty bad. I want to just get a new gasket and ring package and put it back together, but before I do, my questions are these:
1. The walls of the pump body where the gears spin are slightly rough. You can"t really see it but you can feel it if you rub your finger over it. Will this be an issue? Obviously perfectly smooth is preferred but I"m not sure how much tolerance this pump will have. The actual gears look good.
2. If the above is an issue, am I better off leaving it as it is or attempting to smooth it out with emery cloth or something similar?
3. Assuming it"s worth it to get the gasket kit and rebuild it, any idea of a good place to get the gasket kit? I didn"t see any available from this site.
Thanks.
Ben
