Re: Will I need to change? Using an 8 volt batt on 6 volt...
Posted by John T on January 09, 2011 at 07:16:51 from (66.87.5.129):
In Reply to: Re: Will I need to change? Using an 8 volt batt on 6 volt... posted by mkirsch on January 09, 2011 at 05:43:55:
Sorry, I just dont have much IHC data/specs to draw on buttttttttt I think they had 2 coil relays (cutout and regulator) and I think that 2nd relay was a combination VOLTAGE AND CURRENT controller and if so IT NEEDS ADJUISTED FOR BEST CHARGING.
Bob M may have that info, I have more for Deere stuff.
John T
