Re: Will I need to change? Using an 8 volt batt on 6 volt...
Posted by karl f on January 09, 2011 at 10:15:00 from (172.129.46.209):
In Reply to: Re: Will I need to change? Using an 8 volt batt on 6 volt... posted by John T on January 09, 2011 at 07:16:51:
in my experience, 2 coil regulators are square box and 3 coil are rectangular. (forgetting about cut out systems in this instance, as they can fit those basic descriptions in appearance so you must know how to tell them from a regulator).
karl f
