I push our 400 yard drive off every winter with my C with a C-172 up front and a Saginaw 3 point out back with a 6" blade in back. It gives me both weight and capability to scrape hard if needed. I like the front blade but wish it had power angle like a pickup did. I run without chains until I can no longer push effectively or if ice becomes heavy. Then put the chains on. It is a snow machine. The snow gets so deep here in NE Iowa the last couple years a blower would be nice to get it away, but I manage with the blade nicely. 6 volt system and it starts like a charm even at -15F. I don"t run that well at those temps, but the tractor does. Just remember to check that air cleaner cup for water. Once I had some water in there and the engine kept dying because the ice block blocked all the air to the carb. Took me a bit to find that.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
