Re: Farmall 100 pops
Posted by Dave BN on July 08, 2000 at 20:39:05 from (205.188.193.39):
In Reply to: Farmall 100 pops posted by Bill on July 08, 2000 at 20:20:21:
Need more info. Do you have good power or have you noticed a loss of power lately? Does it do this when engine is cold or only when hot? Is the engine running too hot? Quick way to check compression is to pull coil wire off so engine won't start and turn it over either with a crank or with the starter and see if each cylinder has the same compression or does one of them seem weak. This info will help diagnose your problem. Dave BN
Post A Followup
: Re: Re: Farmall 100 pops
