Re: Re: Farmall 100 pops
Posted by ltf in nc on July 09, 2000 at 07:57:43 from (206.228.214.113):
In Reply to: Re: Farmall 100 pops posted by Dave BN on July 08, 2000 at 20:39:05:
As previously stated, need more info. Is popping at a uniform interval or random? If it is uniform, you may have a bent pushrod or valve. If the popping is irregular, the problem could be improper point clearance, timing, or burned points. Irregular popping is typically electrical related and not carb symptoms. Gas symptons are failure to rev or make power, black smoke, hard starting, idle, etc, but not popping.
Post your findings.
Post A Followup
: Re: Re: Re: Farmall 100 pops
