Jump starting M-- Help
Posted by Buck Clayton on January 09, 2011 at 19:21:39 from (68.13.254.121):
The 1939 M LP has been setting for about 2 yrs. Has no battery. I tried to jump start it with the SM (12 volt with alt.) hooked to top of starter switch and neg. cable to starter bolt.Both cables where hooked to SM battery first. When pushing starter switch in, fire shot out from ground connection.Motor did not turn. Checked ampmeter on SM and not charging. Alt . blown. Never heard of this befor. Need help. Buck
