Re: Jump starting M-- Help
Posted by scotc on January 15, 2011 at 06:13:18 from (72.101.50.91):
In Reply to: Jump starting M-- Help posted by Buck Clayton on January 09, 2011 at 19:21:39:
You could just stick a cheap 12 volt battery in the Lp tractor. It only gets used for starting, so it will run it a while between having to charge it. A remote jumpstarting stud would also let you hook the cables to it without having the chance of shorting onto the switch housing or the starter rod.
