Re: Farmall M Rough Idle
Posted by Janicholson on January 10, 2011 at 14:19:57 from (199.17.6.126):
In Reply to: Farmall M Rough Idle posted by Jim R on January 10, 2011 at 13:11:54:
Three items. The carb shop refered to has a reputation on this site that is not complementary.
If the M has a magneto ignition it will idle rougher than a distributor equipped M (no centrifugal advance) If your engine has a distributor it is good to check the centrifugal advance to assure it is working as designed.
If it is possible to smooth it out using the choke, it is lean. if it is rich, screwing out the idle needle (near the top of the carb) leans the mix. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
