Re: Farmall M Rough Idle
Posted by Jim R on January 10, 2011 at 14:39:39 from (152.132.9.197):
In Reply to: Re: Farmall M Rough Idle posted by Janicholson on January 10, 2011 at 14:19:57:
Thanks for the comments and advise so far! I'm not a "mechanic" but I'm learning a lot here. As far as the reputation of the carb. shop that I used, I discovered that after I had already used them. I had another friend with a Farmall "C" that used them and he had to send the carb back to them the second time to get it done right. My Farmall "M" is a 1951 model and has the IH Distrubutor that is horizontal, with the coil on top of it. It is still a 6 volt Positive ground. When I first start the tractor up, it is very rough running when cold, but if I leave the choke pulled out a little, it smoothes right out but has to be good and warmed up before the engine really smoothes out without the choke out part way. I hope this helps you to advise me. I will check on the adjustment of the carb and govenor linkage. Any other advise would be appreciated!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
