Re: Finally got her charging...Sorta
Posted by LarryT on January 11, 2011 at 01:01:58 from (68.35.57.27):
In Reply to: Finally got her charging...Sorta posted by Fullers Farmalls on January 10, 2011 at 16:44:38:
I'd say your ok. Just for peace of mind you might want to run the wires to the regulator just to see if you have a bad spot in the insulation where it could be intermittently grounding. What does the ammeter read when you have everything turned off?
I have seen those old meters get out of calibration and read all over the place on a full battery. IT could actually be cycling from positive to negative slightly and if the dampener is bad that could be highly exaggerated. But I am also a believer in the smoke test. If it's charging and keeping up with the load and it isn't SMOKING, then you should be ok. LarryT
