Finally got her charging...Sorta
Posted by Fullers Farmalls on January 10, 2011 at 16:44:38 from (72.77.118.164):
Took the genny off for closer inspection and found that the field terminal wire was broke off. So i fixed er up and she showed charge. I know its not perfect cause the charge was bouncing between plus 3 and plus 10 amps at full throttle. Then when i would jump a wire from the field terminal to a solid ground it would jump to around 20. Is this normal or should i be looking for something else?
And a special thanks to Jim and John T, you guys really helped me so THANKS! -Keith
