Re: Finally got her charging...Sorta
Posted by John T on January 11, 2011 at 06:06:10 from (66.87.11.125):
In Reply to: Finally got her charging...Sorta posted by Fullers Farmalls on January 10, 2011 at 16:44:38:
That 20 amps with a dead grounded field sounds like the genny is fine. As far as a jumpy needle (if excess) , that can be due to several things such as: Loose brush hold down springys,,,,,,too short brushes,,,,a dirty oily or rough or not properly undercut commutator,,,,,,,,,burned or carboned relay contacts in the voltage regulator,,,,,,,, a loose connection especially a bad loose ground somewhere,,,,,,,,a faulty ammeter.
Id be tempted to clean n polish up the gennys commutator and maybe run a dollar bill between the VR"s relay contacts to clean them and check n clean the grounds n wiring connections
Thanks for teh feedback
John T
