Re: Farmall Super H brakes
Posted by GordoSD on January 15, 2011 at 14:44:43 from (216.106.243.6):
In Reply to: Farmall Super H brakes posted by D Ervin on January 15, 2011 at 10:30:04:
As stated if you didn't have the brake drum surfaced planed it likely won't work very well.I'm not sure where Jim got the .050 spec but that seems pretty close. I use the KISS method and just plane off .100.
Your discs are glazing because they aren't being pushed together hard enough and are slipping even with extreme pressure on the pedal.
Let us know how they work after the planing.
Gordo
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
