Re: Farmall Super H brakes
Posted by Janicholson on January 16, 2011 at 15:51:11 from (67.72.98.45):
In Reply to: Re: Farmall Super H brakes posted by GordoSD on January 15, 2011 at 14:44:43:
The .050" came from experience. I figure it needs clearance at all 4 friction surfaces, so I gave it a little more than .010 each. This works, I have never seen a specification. The angle of pull on the short links going from the plates to the pull rod is very important small changes make large pressure differences. With wear on the metal pieces this .050" can become more like .175". The plates then need to move so far that the geometry is wrong, even with new plates. Jim
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
