Re: Farmall H - 5th gear only???
Posted by Haas on January 15, 2011 at 17:48:59 from (75.216.210.31):
In Reply to: Farmall H - 5th gear only??? posted by Matt Weltz on January 15, 2011 at 17:15:50:
5th gear is direct drive where the input transmission shaft is direct coupled to the rear shaft that drives the differential. The bottom shaft in the transmission has all the other gears that drive the rear shaft. So...it's likely that the constant mesh input gears that drive the lower shaft are stripped. If it is the input gear at the top, it's not a huge job to change that. To find out for sure what is wrong, you will have to pull the transmission cover.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
