Re: Farmall H - 5th gear only???
Posted by Bob M on January 15, 2011 at 20:08:58 from (67.240.171.41):
In Reply to: Re: Farmall H - 5th gear only??? posted by Haas on January 15, 2011 at 17:48:59:
A quick check to determine whether constant mesh gearset has failed: Engage the PTO then let out the clutch with the gear shift lever in neutral.
If the PTO shaft spins normally, the constant mesh gears/lower tranny shaft are OK.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
