Re: Super M wont keep running
Posted by Allan In NE on January 16, 2011 at 04:03:48 from (148.66.88.254):
In Reply to: Super M wont keep running posted by Letterman on January 16, 2011 at 02:47:14:
Sediment bowl screen, carb screen, standpipe partially plugged, point adjustment, coil or coil wire.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
