Posted by Letterman on January 16, 2011 at 02:47:14 from (208.74.247.249):
I have a Farmall Super M. It's always ran well. We've been having severe cold weather, so I originally suspected some ice in the gas. I've put in 4 containers of HEET in the last few weeks. The problem just wont go away. Even when we had on a few warmer days (above freezing).
Here's what it's doing. It starts fine, choke is fully closed. As soon as it starts I open the choke slightly and it runs great. But after a minute or so it begins to spit and sputter. loses power, and on occasion shoots a flame out of the muffler. Going up a hill or any load, such as pushing snow with the loader makes it worse. The longer it runs the worse it gets, and just to keep it running I have to fully close the choke, and keep it closed. It will stay running that way, but if I try to push any amount of snow, or a round bale, it struggles to stay running. At this point, if I open the choke, it shuts right off.
If I shut it off, and let it rest for a few minutes, it will once again run well for a minute and then repeat this all over again. It most definitely seems to act like it's running out of gas, more than an electrical issue, but I wont rule out anything. I am not low on gas. I have not tried to adjust the carburetor, because it does run well when I start it, and was running well prior to this issue (and I dont recall what screws to adjust either). The bowl is filled with gas even after it begins to run poorly.
One thing I am also noticing is that the top part of the carburetor and lower end of intake manifold become encased with frost on the outside after it runs for awhile. I was told this is normal, but I never noticed it in the past, but at the same time, I dont normally look at the carb when the tractor is running well.
What could be the cause of this? I should mention that on occasion it will run perfectly fine for 10 or more minutes, but the next time I use it, the problem returns. I'm puzzled, and it's too cold outside to start ripping everything apart not knowing the exact cause, other than it's most likely fuel related.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
