Re: Super M wont keep running
Posted by d. beatty on January 16, 2011 at 07:56:26 from (71.239.246.137):
In Reply to: Super M wont keep running posted by Letterman on January 16, 2011 at 02:47:14:
Check the fuel system as the fella above said. You said you had trouble with carb. iceing up.It is posablethe throttle plate is freezing up.had a ih b that would freeze up. took a 6" stove sliped over muffler and made a pipe from stove pipe to top of air cleaner stack. carb. never freezes up. i take it off in warm weather.we have used for 30 years with no problems.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
