Yes check the fuel flow to carb, should be a full stream. If not, make your way up stream to the tank and don't forget to make sure the fill cap is venting properly. If you have a full stream, the fuel isn't getting past the needle. I recently fixed a carb that the fuel level was too low and would only let in a little fuel. Another time I found a bad float. But before you open up the carb, remove the fuel line and make sure that nothing is blocking the fuel before it gets to the carb.
One more thing, check your coil. That is also typical of a weak coil.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
