Re: dead starter?
Posted by Big M on July 10, 2000 at 08:23:41 from (198.133.22.66):
In Reply to: dead starter? posted by shawn on July 09, 2000 at 19:59:55:
Sounds like you have a flat spot on the starter.
Disconnect everything, take your starter off and
give a turn or two with your hand. Place it back
on the tractor and try turning it over. If it starts, take your starter in to a nearby starter
repair shop and have it gone through, you may have
some bad brushes inside.
Hope this helps ya.
Big M
Post A Followup
: Re: Re: dead starter?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
