Re: 300 acres corn soybeans, what HP tractor
Posted by glennster on January 17, 2011 at 18:16:42 from (99.90.9.153):
In Reply to: 300 acres corn soybeans, what HP tractor posted by arod on January 17, 2011 at 16:45:29:
with 300, you will probably be doing primary tillage and planting. hire out the combining. buying a combine for that size farm is a money pit. you can no till corn and beans, hire out the spraying. do you have grain storage and a dryer? jd 7000 is a good solid planter, easy to get parts for. working full time and nite and weekend farming, you need at least 100 hp, maybe up to 180 hp, depends on whats in your area. older case and allis chalmers can be bought cheaper than an i-h or jd. a second tractor with a loader is almost a must have too.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
