Re: H throttle position
Posted by gene bender on January 18, 2011 at 09:01:21 from (67.55.227.196):
In Reply to: H throttle position posted by Melnick on January 18, 2011 at 08:16:50:
throttle position shouldnt have anything to do with starting. Remove all plugs hook their wires up make sure they are grounded then hit the starter and observe fire on all of them you can even put your thumb in the hole to see if the spark fires when you feel the compression stroke this will tell you the rotor is in time also. If that checks out your problem then is in the fuel system like sucking air somewhere bad fuel supply carb needs good cleaning and is the gov hooked to the carb correct. Thats why we do the fire first and i checks out you know its fuel.
