Posted by Melnick on January 18, 2011 at 08:16:50 from (66.146.239.205):
I have aquired an H with 12 volts system and magneto. The throttle position must be full off or this thing will not start. This just doesn"t seem right to me. What adjustment(s) are in order?
Also, this tractor is just a bear to start when its cold outside. I normally end up heating the manifold and sparkplugs to get it running. Any help would be appreciated.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
