Posted by Janicholson on January 18, 2011 at 10:03:21 from (199.17.6.165):
In Reply to: H throttle position posted by Melnick on January 18, 2011 at 08:16:50:
If the starter spins the engine fast enough the impulse coupling will not engage. It will however not have enough velocity to start well without the impulse. If it spins over pretty fast, this can be the cause. Shutting the throttle causes it to turn some what harder pulling against a vacuum. (not always) If it pull starts easily with the throttle at any position, I would suspect this. A leaky intake manifold is also a possible source of vacuum leak. Some are cracked on the inside of the manifold. Using a 6 volt battery (and alternator, they are available) or generator, will slow it down if the speed is causing the issue. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
