Re: Winter Battery Storage
Posted by jdemaris on January 18, 2011 at 11:59:15 from (67.142.130.16):
In Reply to: Winter Battery Storage posted by Orange on January 18, 2011 at 09:42:06:
Temp has nothing to do with it. All lead-acid batteries self-disharge - all by themselves. 2% to 5% per month. And they all get damaged over time if left sitting in undercharged condition.
A 12 volt battery needs to read around 12.7 volts to be fully charged. When it reads 12.2 volts - it's already 50% discharged. At 11.9 volts it's basically dead. Buy a $3 voltmeter and check once in awhile.
Best way to store is to make sure they stay charged. Stick a charger on them once in awhile or hook to a battery maintainer.
By the way, I understand the idea of using a $15 maintainer gets some people furious around here. So, do you own research. In my experience, they are cheap, work great, and are very safe.
A 2 amp maintainer uses 24 KWH if hooked for a entire year (on a good battery). That's a annual electric cost of around $4 in the highest rate areas. Of better put, $2 for an entire 6 month cold-season.
