Posted by Andrew Z on January 18, 2011 at 16:36:05 from (64.252.115.246):
In Reply to: Farmall 400 Diesal posted by Jeff338 on January 18, 2011 at 15:38:58:
Butterflys are closed are in the closed when in the gas position. You really need to get the manual for it, there are alot of linkages and connections that need to be set in order for everything to run right. A manual would really be your best bet. Very hard to expalin the whole system.
And the switch you talk about is in the intake manifold. You may need to clean and check the contacts in there. Removal of the front plate on the intake will show that. A manual would help again here.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
