Re: Farmall 400 Diesal
Posted by d282 on January 18, 2011 at 18:12:01 from (166.235.152.75):
In Reply to: Farmall 400 Diesal posted by Jeff338 on January 18, 2011 at 15:38:58:
Pull lever back, towards you to start on gas. Sometimes you have to hold them back because of wear etc. Once it is warmed up, advance throttle and push lever forward. It will sputter but hopefully take off. If it sounds like dying, pull lever back and try again after if is running on gas again.
To shut off, I always pull throttle up in the summer, but will let it run again on gas for a bit in the winter to help it start again, but always before getting off, throw the lever forward to the diesel position.
In the archives, there are some more detailed instructions.
Good Luck!
