Do you plan on working the tractor or is it just a parade\light duty yard work tractor?
A drop in oil pressure once the oil warms up is normal. Do you have any noise in the engine that would indicate low pressure? Knocking, tapping? Fist thing I would do is get a new gauge that will go as low as 5lbs of pressure on idle. Maybe your gauge is bad or the sending unit is bad or dirty? I have had engines that run great and showed 50 psi+ when cold and less then 10psi at a hot idle. Heavier oil and I increased the psi by 5-10 lbs. If you're not going to work it hard and it's not rattling leave it alone and enjoy it. My .02
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
