Re: Super H Low Oil Pressure?
Posted by rustred on January 19, 2011 at 13:15:40 from (74.200.18.155):
In Reply to: Re: Super H Low Oil Pressure? posted by shawnm on January 19, 2011 at 12:02:00:
definitly not normal for oil pressure to drop off when warm.that tells you have increased brg clearance and the pump cant hold the pressure. at idle the guage still should be around 3/4 to the end, not dropping to 1/4. these guages are manual oil operated without sending units.what you are saying about your tractor by increasing with heavier oil is true because your brgs are worn also.
