Posters, putting 2 pictures on. Fixing up a M for a user tractor out of parts I have. thought this would work but wondered if there would be a problem after getting into it. Don't have the hoses on yet, but you can see the openings. Planed to have the oil level 1/3 to 1/2 in the top tank. Mostly using it for expansion so the lower can be run full. Upper tank is from a 400 tractor turned backwards. Outlet is taped to the same passage as used on the 400 and plates on top sealing the regular outlet. Planed to return oil to the lower opening in front of top reservoir. Made a baffle droping down from plate on top of reservoir to the inside to baffle the return port. Vent port is on the other side of the reservoir and exstends to other side of the baffle near top center of the reservoir. Lower belley pump housing is just a empty housing now with all but top and bottom holes pluged and inside cleaned. I can put a screen in place of the bushing in lower reservoir, or use the 400 screen in the upper tank.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
