Posted by D Slater on January 19, 2011 at 05:54:14 from (184.15.34.211):
Adding oil capacity to tractor by mounting another reservoir above the existing one. Joining with a one inch line. Suction line to pump one inch size from near bottom of lower reservoir. . Lower reservoir sealed except for line from upper reservoir. Upper reservoir vented. Plan to return oil from open center valve bank to upper reservoir. Is it better to return oil below or above the oil level in the reservoir? Also the upper reservoir has a suction screen that can be installed so the outlet line oil to the lower reservoir goes through it. Would this cause a problem? Fixed it so I can put a screen at the lower reservoir suction line and leave the other out if needed, but would have to purchase it and already have one for upper suction to lower tank. Thanks for any thoughts or advice.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
