If the system is clean to start with, a filter on the return is best just as M Diesel said. On our test machines and customer machines (tractors, skid steer, swathers, combines, etc.), we filtered the return with a finer mesh, in our case a 10 micron filter and customers sometimes used a 25 mic. On customer machines, there was typically just a screen on the suction, but on our test machines we installed a large 74 or 49 micron screen element. We also on test machines had a circulating system, which you will not have on a tractor or implement, that had a large capacity 10 mic filter as well as a cooling or temperature control system.
A couple of things to consider here.... 1. You can not use a very fine micron element in a suction line, because as the filter fills with contaminant, it will "choke off" really quickly, like a snowball effect. and 2. In cold weather conditions, or even just normal cold start conditions, the filter will not flow as easily. Like I said, we over-sized the flow capacity and used a 49 or more often, a 74 mic cleanable steel element.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
