Re: Super c hydraulic fluid?
Posted by mkirsch on January 25, 2011 at 05:16:37 from (64.80.108.56):
In Reply to: Super c hydraulic fluid? posted by Sam eubanks on January 24, 2011 at 19:20:52:
In this case, the book will only serve to confuse you. It was written in the mid 1940's when "hydraulic fluid" did not exist.
A lot of people waste a lot of time looking for "non detergent" motor oil as specified in the manual.
CaseIH HY-TRAN hydraulic fluid is what you should use. Fill the reservoir until it runs back out, and it's full.
