C charging problem
Posted by burnsg2003 on January 27, 2011 at 18:06:22 from (205.188.116.73):
I have a 1951 C that I rebuilt. I am having problems with the generator charging. I had the generator rebuilt and ended up buying a new regulator. When I first put everything back the amp gauge did not show any charge since I had repainted a lot of the tractor I thought I was not making ground so worked on that and my amp gauge would move to the positive side maybe 5amps. Can anyone tell me when charging hard what the gauge should read. Even though the generator was rebuilt I suspicion something wrong is there any way to use a voltmeter and hook to the generator to see if it is running. Even though the gauge is moving it is not charging enough becasue every time I run the tractor the battery runs down and I have to charge it. Any help or ideas would be appreciated.
Greg
