Re: wiring and hyd
Posted by K-Mo on January 30, 2011 at 07:43:48 from (67.55.164.37):
In Reply to: Re: wiring and hyd posted by John T on January 30, 2011 at 07:13:47:
A comment to add about using a resistor.
The IH 184 Cub LoBoy for example and some other IH tractors use a resistor. It's a 25 ohm p/n 534784R1/107558C1.
Although your suggestion for using a 10 ohm resistor may work in many cases, it may be a little border line. I tried a 12 ohm resistor on my 184 which worked, but if I shut the tractor off above idle, I could tell it fired a few extra times before stopping. I could tell the difference when I installed the correct 25 ohm resistor.
K-Mo
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
