Re: wiring and hyd
Posted by John T on January 30, 2011 at 10:47:20 from (66.87.4.252):
In Reply to: Re: wiring and hyd posted by K-Mo on January 30, 2011 at 07:43:48:
Very good point, Ive seen up to a 147 ohm used which still allowed for excitation plus provided even more current limiting protection, however Ive seen only a 5 ohms that worked and prevented run on also. It depends on the RPM and the alternators characterisits and regulation etc etc
Hey if she runs on at 10 ohms increase it Eh
John T
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
