Re: Another not a IH question, but not luck on other forum
Posted by Janicholson on January 30, 2011 at 16:24:13 from (67.72.98.45):
In Reply to: Another not a IH question, but not luck on other forum posted by clint s on January 30, 2011 at 15:51:56:
All differentials, both Hypoid and bevel gear (like in yours) require shimming or adjuster movement to make the pattern correct. Failure to do so will have a 5% chance of being even close. The only way putting it back together the same would be if every component was the old component and they were meshed correctly to begin with. If you are not the person to do the tooth pattern reading and adjustment Find a volunteer that does. Buy frosty Malted beverages and watch the process. It needs Dial indicators and possibly calipers, Prussian blue, spring scales as well as original specifications. Jim
