Another not a IH question, but not luck on other forum
Posted by clint s on January 30, 2011 at 15:51:56 from (24.92.241.43):
I posted this on the Ford forum with no replies maybe someone here can help.
I am assuming my Farm Trac 555DTC is the same or very similar to the 3620 Ford. The bolts in my pinion bearing carrier came out and wrecked the pinion bearing and pinion shaft and and gear. After waiting months for parts I am ready to put it back together. Do I just slap it back together or do I have to shim it like a car rear. I see nothing in the parts breakdown for adjustment/shimming. Am I correct in assuming that because it is a low RPM rear I just put everything back together the way it comes apart.
I am replacing part #5 on page 5 the pinion shaft and gear.
My tractor uses the 32,33,34,35 set up and the only "thrust" washer I see is 33 and that between the transmission side
http://lib.store.yahoo.net/lib/yhst-97092812362812/parts545-555v3.pdf
