Re: Can you use a self unloading wagon on an ensilage blo...
Posted by karl f on January 31, 2011 at 14:41:51 from (209.188.106.159):
In Reply to: Can you use a self unloading wagon on an ensilage blower? posted by NNY FARMER on January 30, 2011 at 20:06:54:
our blower tractor was a stock "49 Minneapolis Moline. We had a Kools Bros blower. Worked just fine with the 12 ton Kasten front unloading wagons. When using 1256 or the other slightly smaller IHs when the MM was down, the old U seemed just as capable with that blower. When too much silage would come down the beaters, it didn"t matter which tractor as the shearbolts would break. a half ton all at once is too much :)
An older blower requiring an H Farmall for power is likely designed for hand unloaded wagons. You can put a little more power to the blower to maintain its max capacity, but the blower capacity is still limited by its desgin.
good luck
karl f
