Re: Another not a IH question, but not luck on other forum
Posted by Janicholson on February 02, 2011 at 07:44:59 from (199.17.6.165):
In Reply to: Re: Another not a IH question, but not luck on other forum posted by clint s on February 01, 2011 at 18:07:47:
.004 to .006" of circumfrential rotation (measured at the outer edge of the ring gear, tangent to the edge) will be a good guess.
The gear (assuming it is either a spiral bevel, or straight cut bevel) will be fine if it has full length tooth contact, and a wipe pattern that is consistent along the tooth drive face.
Pinion preload is another guess it should resist turning by hand, and stop when trying to spin it.
It should not be so tight that you cannot turn it by hand on the pinion gear. Jim
