Re: Another not a IH question, but not luck on other forum
Posted by clint s on February 01, 2011 at 18:07:47 from (24.92.241.43):
In Reply to: Another not a IH question, but not luck on other forum posted by clint s on January 30, 2011 at 15:51:56:
Well here is an update since I bought the service manual. There is no mention or spec for backlash of the gears. It goes through the process of setting bearing preloads ect. Gives specs for those. Here is the the only thing is says on the gear backlash:
NOTE: It is advisable always to check on reassembly that the differential ring gear can be turned by hand and that backlash exists between the drive pinion and differential ring gear. Excessive pre loading or end float conditions are both detrimental to the life of taper roller and pilot bearings.
I will talk to the dealer monday, so I really don't know.
