Re: Another not a IH question, but not luck on other forum
Posted by clint s on February 02, 2011 at 16:09:42 from (24.92.241.43):
In Reply to: Another not a IH question, but not luck on other forum posted by oldiron29 on January 30, 2011 at 15:51:56:
They gave a spec for pinion preload and I got that set. I will still check the backlash with grease to make sure. There is no way to measure the backlash with a feeler gauge as once you put everything together there is only about a 2 inch by 2 inch window you can see the rig gear through and the pinon gear is out of sight.
This is why this is a great forum. I got one reply on the Ford forum about this.
Clint
