Posted by Paul f on February 05, 2011 at 08:35:28 from (206.158.36.249):
One of the 2 metal tabs welded to the gas tank on my M is broken off. (Base is there but the little tab is gone).
Leaves no way to latch the hood.
Is there some clever/alternative way of securing the hood. Concept of removing the tank purging it, filling it with water then trying to braze or weld something on seems like too big a project.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
