Posted by John M on February 05, 2011 at 09:00:23 from (67.231.169.173):
In Reply to: Farmall M Hood latch posted by Paul f on February 05, 2011 at 08:35:28:
I have one like that, I got one of those screw type hose clamps and worked in there and with some trial and error adjusted it until it held the hood down. its not perfect, but it works. Your may not be messed up like mine was though.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
