Re: gasoline powered 7.3 Power Stroke
Posted by 43warhorse on February 05, 2011 at 18:45:08 from (174.252.60.246):
In Reply to: Re: gasoline powered 7.3 Power Stroke posted by Marty from MN on February 05, 2011 at 16:37:18:
Ok let me be a little clearer. A 7.3 is not a direct injection
diesel, an air fuel mix is induced into the chamber by a intake
valve. The intake valve opens as the piston is traveling down
from the exhaust stroke, sucking the mix into the chamber.
The compression on a diesel is so at TDC the mixture ignites.
Diesel fuel has a high flash point requiring a higher
compression. Gasoline has a much lower flash point requiring
less compression, thus igniting before TDC in a 7.3. A gasoline
internal combustion engine will destroy itself from preignition
over a period of time, low compression. A diesel on average
runs 3 times the compression, so it does not take long to
destroy it with preingition.
A Duramax on the other hand is a direct injection diesel. Air
is the only thing coming thru the intake valve. The diesel fuel
is directly injected to the combustion chamber just before
TDC. Gasoline would have the same effect in this engine also.
Detonating as soon as it was injected.
Lastly the oiling system on a diesel is differet from a gas
engine. It is called fuel oil for a reason, it has lubricating
properties the engine relys on. Gasoline has no lubricating
properties and runs a diesel dry burning up components as it
flows thru the system.
